Looking for left rear door tinted glass for 53 Hornet 4dr sedan
Kdancy
edited August 2016 in HUDSON
 I'm installing the windows back in the 53 Hornet 4dr sedan I have been working on.
The drivers side back door glass is factory tinted and has a 6" crack on the bottom.
I'd like to replace it if I can find another one, doesn't matter about some de-lamination, just
needs to be in good shape.
Anyone ?
    Upate ---- The local auto glass shop installed the new tinted laminated glass into the window track.
I have it installed and can't tell the difference in color, good match.
Total was 106.00 including tax.
  • Kerry,let me know if you find more than one,same one cracked on mine.
  • Take the dead window to one of the larger glass merchants, they will be able to cut one for you in the correct colour and thickness laminated glass.
  • Kdancy
    edited August 2016
    Bob, after reading your post, I called my local glass company and they said they could cut me a new one in Green Tint laminated glass. So, I will take it over monday and see if they actually can!
    Thanks!!
    Update, just went on over and dropped it off. Will report back when I pick it up.
  • Updated in first post.
