hydro or BW auto
I have been messing with my Hudson for close to 30 years now but never had much to do with the automatics, just manual. I may be going to look at a '54 in a week or so and the owner says it has a dual range hydromatic. I am aware that this maybe true but the majority of the '54s has BW autos due to the Hydromatic fire in '53. I believe that the selector detents between the two are the easiest way to know which is which, correct?
The HydraMatic will have D4 and D3 positions instead of just a D position.0
The BW has a "Park" position at the very left side of the quadrant. Also FYI the BW were only used up until mid January as the new Hydramatic plant came on stream at that time.
Dan, If you get the car on a lift, look for the tranny crossmember. The hydramatic has a straight crossmember. The BW has one that is curved.0
Thanks guys for the help.Dan0
I'm curious also of opinions between the two.Does the BW have more/less issues than the hydra? How do they compare performance wise?My 52 has a single range hydramatic. I've talked with someone who has a 54 for sale, but it has a BW and I've not any experience with one.0
Bull, it is my understanding that most enthusiasts consider the BW to be inferior to the Hydramatics. I don't know the specific reasons why, however. My '54 has a Hydra, and I suppose it works well for being as old as it is, but it slips and probably needs a rebuild sooner than later...0
Bull, the torque converter in the BW unit is somewhat loosely coupled, so you don't get the more solid feel that you get from the HydraMatic. I definitely prefer the latter.0
We found that the BW would handle the 232 & 262 pretty well, but the Hornet 308 was another matter. All that torque from the big engine would eat the BW up big time if the driver regularly got one the 308 at traffic lights.
Hmmm. A single-range in a '52? Maybe carry-over from the '51s but more likely a transplant. In either case, they're known to be nearly bullet proof. Recall the B&M Hydros from the early drag racing days?
F
The Dual Range Hydro was not available on Hudsons until about Feb or Mar 1952, so it is possible for early production cars to have the old single range unit.
The Dual-Range feature was linked to the introduction of the Dana rear axles with 3.07 ratio. It allowed you to stay in 3rd when driving in traffic at moderate speeds. Without that feature you could find yourself bogged down a bit if in 4th gear.0
