Need '37 Tp front suspention parts
ajet
For '37 Terraplane 2dr sedan w/ "axle struts" , "floating" type ft axle... :
BZ 153228 front spring seat & cap assy.
I need every thing that attaches the leaf spring to the axle on one side ... seat, U bolts, nuts, and piece under u bolts on top of spring.
I've been led to believe '37 , '38 & '39 are the same.
Thanks Bill
Thanks Bill
I think a lot of that is universal-type stuff, but can't give you exact examples or part numbers. You might take the old parts with you, to a good parts house (where the counter person has some knowledge).
Your local Spring Shop will have or should be able to make the U-Bolts and have the Nuts in stock. I think your looking for the 'Clamp' that goes around the Axle with a Zerk Fitting? If so. I might have it and will look over the wknd.
Thanks guys,
OL racer ... You are right, that's the main piece I need , Have a good holiday and hope you find it ...
Jon ... in my searching coupes and pickups have a more "common" spring/axle connection ... mine is different
as OL racer figured ...
TNX Bill
Ive found '37's without sideTorque Arms have the more common spring 'perch'.
A JET I'M TAKING OFF ALL THE STUFF YOU NEED FOR YOUR CAR EMAIL ME OR CALL XXXHUDSON1957@AOL.COM MINE IS A 390
Paul ... email sent ... tnx
TNX Everyone got the parts ...
I got the U bolts off E Bay ... Indiana U Bolts Inc. Part# S132
1/2" x 1 3/4" x 6" , bit long but nice fit ( EZ to shorten )
