Need '37 Tp front suspention parts
For '37 Terraplane  2dr sedan    w/ "axle struts" , "floating" type ft axle...   :
BZ 153228 front spring seat & cap assy.
 I need every thing that attaches the leaf spring to the axle on one side ... seat, U bolts, nuts, and piece under u bolts on top of spring.
 I've been led to believe  '37 , '38  & '39 are the same.
 Thanks     Bill
  • I think a lot of that is universal-type stuff, but can't give you exact examples or part numbers.  You might take the old parts with you, to a good parts house (where the counter person has some knowledge).
  • FYI
    Your local Spring Shop will have or should be able to make the U-Bolts and have the Nuts in stock. I think your looking for the 'Clamp' that goes around the Axle with a Zerk Fitting? If so. I might have it and will look over the wknd.
  • Thanks guys,
    OL racer ...  You are right, that's the main piece I need , Have a good holiday and hope you find it ...
    Jon ... in my searching coupes and pickups have a more "common" spring/axle connection ... mine is different
    as OL racer figured ...
    TNX      Bill
  • FYI
    Ive found '37's without sideTorque Arms have the more common spring 'perch'.
  • A JET I'M TAKING OFF ALL THE STUFF YOU NEED FOR YOUR CAR EMAIL ME OR CALL XXXHUDSON1957@AOL.COM MINE IS A 39
  • Paul ... email sent ... tnx
  • ajet
    edited December 2016
    TNX Everyone got the parts ...
    I got the U bolts off E Bay ... Indiana U Bolts Inc.  Part# S132
    1/2" x 1 3/4" x 6" ,  bit long but nice fit ( EZ to shorten )
