Rear Bumper Help
There's three pictures in this album if that helps. You'll have to wade through the others.0
Thanks Steve
Mounts look a little different than my 1950.
They look stronger with more metal in them.
Larry
Larry - take a look at Adalanto Ca for your saltypiece of land. Lived in the high desert 3 years.0
Side view of a '53 rear bumper bracket(s). Original purpose was to show LED lites behind bumper, not bumper mounts per se.
might help, don't know~~
Old Farmer,
Adalanto used to be in the service territory that I covered as tech support.
Are you also ex-Air Force?
I covered from Barstow to Paso Robles down to Oxnard and back to Palmdale.
Richard,
Look like yours are also beefier than mine.
Thanks
Larry retired USAF 1989/22+ years. I worked for Lockheed ADP and lived in Victorville. As a teen always wanted to go to Murdoc drylake and witness the time trials. As they say be careful of what your wish! I was an active member of the CIC then. Newsletter editor at the time too. The best way to align you bumper mounts is to support the bumper and ends (bolt it together) and using the mounts align the bumper Holes. Good luck with your car.0
I was only 4 years USAF. C-5A Specialist @ Travis AFB 1971 - 1975.
Thanks again,
Larry
- 96 Essex Super 6
