47 hudson super six pick up truck
Go to YouTube type in the search hudson6037 truck is black let me know what u guys think please.0
Hudson6037 YouTube search bar I uploaded this video0
Watched the video, looks like a decent project.
- If it has a 308 dual carb engine in it, it is not original. They came with a 212 cu in 'splasher' engine. The 308 would be from a later Hudson, and is a somewhat common 'swap', along with the 3-speed and OD.
- The bed would / should be wood w/metal slats;
- A rear bumper is not stock. They came without one;
It should have a 'wet' cork clutch. About the only issue with them is that the clutch tends to 'stick' to the plate, when left for periods of time. It requires about 6 oz. of Hudsonite (clutch fluid), to keep it 'happy', and when maintained is very smooth and reliable.
From the looks of it, the truck looks to some years of neglect & has been stored outside for a while - luckily, that looks like a CA (?) tag, but am not sure.
The missing parts that I have seen from the video are somewhat minor (as long as the underlying metal is solid), and can be found/replaced.
The major points where rust shows are the lower edges/corners of the cab, fenders and doors. On the frame, it is usually the back half, where the 'X' meets the frame (you will know what I mean when you look at the frame under the truck), where it juts upward to go around the wheel well, and where the back leaf spring is supported by the frame.
Value? That's more difficult. Based on the limited view in the video, $3-$5 K would be a decent price, depending on condition (obviously not running).
There were roughly 3200 made in 46/47. There are about 325 46s in the HET roster and about 150 47s. Probably another hundred or so in barns, woods or not in the Hudson club
Probably worth 4 - 6000 with the 308 twin H and OD mostly there and not running.
Larry, HET commercial registrar
Uncle Josh
I tried to send you a PM.
Didn't get it, email HETcramerlp@roadrunner.com0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
