WGD Carter
My '53 Hornet, r.h.d., assembled in South Africa, has never performed up to what I would have expected, and is temperamental when cold particularly. It has a WDO carburetor fitted, which I suspect may not even be off a Hudson. There is no ID tag on it. Does anyone have an original WGD carburetor that I could purchase? According to the 1953 Supplement it should be a WGD-2115S. My car does not have the original engine, but is within the number range for 1953, so it is correct for the car. Any help would be greatly appreciated.
Geoff
Geoff
As Ken said and he is correct, a 776S is what you want. If you can't find them locally, I have them.0
Lance I sent you a Private Message re purchasing a WGD.
Geoff0 -
Geoff, I have replied back.Geoff C., N.Z. said:Lance I sent you a Private Message re purchasing a WGD.
Geoff0 -
My 49 came with a WDO which I'm still using but not real happy with it. I think it evaporates too much fuel. I think the vents are part of the problem. It loses it all in 2 days resulting in excessive cranking. I have a few WGDs on the shelf. I'm going to switch to one to see if it works better. Must have been better, if Hudson switched to them.0
Lance, thank you. However I can't seem to access private messages any more. I wonder what has happened? Could you please email me on NZGeoffclark@xtra.co.nz (leave the NZ off the front). thanks, Geoff
Will do Geoff.0
What carb went on the 8's, specifically a 41 Commodore 8?0
The 41-47 8 cyl. used WDO 502 S . If you find a 501S this is for the 6 cyl. 212CU,0
- 112 Hudson 1916 - 1929
