1950 Commodore dash
KustomKreeps
Well i have been looking at dashboards lately for my project.
NZ being Right Hand drive makes it rather limited.
For the last hour or so as i work away here at work i have also been looking at Hudson dashboards. the 1950 Commodore dash looks pretty much the same as a 49 but shiny.
is this the case? is it the same dimensions/fit as my 49 just with chrome/stainless plate slapped on to it?
Also looks easy to convert to RHD.
Is it chrome?
And finally many about for sale? (who accepts either Paypal/visa or direct credit into there bank account)
Be cool to have a Hudson dash otherwise it will be god knows what as i want a dash with a bit more "bling" & the 49 is totally lacking in that area.
Thanks
Alex
Is it chrome?
Thanks
Alex
Alex, If you're talking about the 1950 dash base, then yes, it will interchange with the 48 & 49 dashes. The left & right glove box doors will interchange as well.Trim on the doors is different with the 1950 doors having cutouts for the fuel/ temp gauges and model name on the respective sides The difference is in the center where the dash gauges go. The 48-9 used round fuel and temp gauges while the 50 had a rectangular pod for same. That means a center section of dash will not interchange. The 1950 was a stand alone. Also on the 1950 dash there is provision for an ashtray. Not so on the 48-9 dashes. Clock & speedo dash holes are the same0
hmm so the dimensions are the same.
So i could take the whole dash out of the 49 - from window and firewall to front face. gauges and all.
then swap in the 50 dash like pictured below - gauges and all.
Alex
Yep. you can. Problem is the aren't a huge number of complete 50 Commodore dashes around. More 48-9 Commodore dashes than 50 dashes.0
Looks good !0
Interesting. Every one I've seen were blue marble finish.
Were there options?0 -
Mine is blue marble, but actually most other '50s I have seen are brown? I am not sure if this was an option or you got either blue or brown depending upon the interior color choice? BTW I believe the Hudson term for these dashes was Velichrome.0
Dan, Velchrome was also the term used for the flat silver on the rockers.0
- 96 Essex Super 6
