WTB Vacuum Reserve Tank
Hi everyone,
We have a '54 Hornet with the Bendix Treadle-Vac Power Brakes but this car has never had the extra vacuum reserve tank and I would like to add it.  Anybody have one for sale or have any leads of where to get one?  Thanks.
Tim in WI.
  • If you can use a Universal; Vacume reserve Tank Jegs Performance has them for $30
  • Jegs has them available for around $50. Non-original but functional, 5"x7".
  • I'd like an original if I can find it but thanks for the lead about Jegs.
  • I think so.  It looks very similar to the one on Ray Byvank's recently restored '54 but hopefully someone else will chime in here to make a positive i.d.  How does it attach to the inner fender?
  • It has 3 mounting tabs on the bottom
  • The vacuum tank Don pictures is a Hudson :1954 tank.
  • Sounds good, thanks.  Don, assuming your tank is in good condition without any leaks, cracks, etc. why don't you PM me and we can talk about price?  Thanks.
  • I have one of these vacuum tanks on the RH fender apron of my 53 Hornet; no power brakes either.  Don't know what it was used for since it is not connected to anything.  Anybody know if Hudson used these prior to 54 and for what?  Thanks.
  • Does it come off the fuel pump into the tank then into the wipers from a duel action pump ?
  • FYI
    If good original vacume tanks are becoming hard to find consider mounting an aftermarket Tank from E Bay $15 & up.....
