Edmund Intake on ebay
  • 50C8DAN
    50C8DAN Senior Contributor
    Someone should buy this as a pattern to make repros!
    Actually, the above is exactly right. Someone should buy this manifold for pattern reasons.
    I'll explain why. I've been working on an EFI system for my engine. Yes, I did finally succumb to some element of modern technology! What makes that particular Edmunds manifold attractive for EFI, is the runner geometry. The geometry that makes it a somewhat less than attractive carbureted option, offers an EFI injector placement that is second to none in the Hudson range of choices. You can basicly discharge the nozzle directly into the center of each intake port. Also, this manifold will fit with long and short hooded stepdowns where the triple weber option will not.
    When it comes to direct port EFI - that particular Edmunds is your manifold. The fuel atomization and avoidance of wetting any intake tract surface may even turn out to be superior to the triple weber EFI system. If an IDA type Weber manifold were available for the Hudson, this injector placement could be replicated and would represent the ultimate for EFI. The triple DCOE is the ultimate for carbureted engines.
    The person I'm collaborating with on this project already makes TBI units that will go on the Edmunds manifold, but the fuel/air situation in the runners will be similiar to a carbureted engine. I'd say still better than a carb, but not optimal. The program to be written also includes timing controls that follow a matrix based on carb inputs rather than a knock sensor. The knock sensor would pick up the mechanical valvetrain noise and possibly falsify your timing inputs.
    So, if anyone is interested in reproducting a Twin carbureted Hudson manifold - don't let this one get away. There will eventually be an EFI option for this manifold, either TBI or MPI. The cost of these systems is looking to be reasonable as well.
    Mark Hudson
  • 464Saloon
    464Saloon Senior Contributor
    Mark you sound like the expert on these as many other things I have seen you post on. Maybe you would be the one to tackle this? I have a line on a complete restored Twin H a guy is selling for 550.00 complete and ready to bolt on. Would this be worth going for or should I hold off for something else. I believe you were the one I was chatting with on a set up using a Twin H manifold and twin two bbls. This might be a good start for now and at least I would have a Twin H. Thoughts or comments?
    Thanks
  • harry54
    harry54 Senior Contributor
    I payed 400$ last summer for a set up that was clean but needed to be bead blasted and painted. No linkage, which I understand is very hard to find. I think I saw linkage alone go for 125.00 on ebay. It sounds like a fair price to me. Good Luck
  • harry54
    I think the reserve on the Edmunds intake is very High. I just bid 145.00 and not met .
  • That would be a good start, yes. The Holley 5200's are good setups. You would have to reverse the mounting of the 5200's from the way I have in the MSN pictures to get your Twin-H to work and pull in the direction of the stock linkage. Here is the catch. That will work on Hornets and Commodores, it will not work on Wasps and Pacemakers. The reason being, The carbs then won't clear the firewall as the fuel bowl is pointed rearward. If you use the single WA-1 "across the head" pull linkage, you can turn your carbs with the fuel bowl facing forward and set the carb linkage up as I have it on the MSN site. Having an authentic Twin-H linkage is always a good thing!
    Here is the good news however. This fella also has single throat TBI units already available. These would be able to fit on the Twin-H and possibly rival a dual 2 barrel in cfm capacity. No venturis in a throttle body - gone is the flow restriction above and beyond the butterfly and throttle shaft.
    The deal is, and holdup, is that he needs a runnning 308 to do some initial matrix work on to iron out the fuel and timing mapping. Rudy Bennet and his AMC distributor setup may be perfect for adapting a late model 4.0 six distributor as it is completely computer controlled and sits static in its timing to the engine.
    I'm not an expert on EFI, by any stretch of the imagination. Sunday, the perverbial "light bulb" popped on above my head and I got in touch with a person who was doing vintage performance stuff. He is interested in obscure engines like the flathead Hudson, Mopar, and Studebaker. We got to exchanging ideas and things look really, really good for us Hudson fanatics.
    It may be possible to have a "bolt on" Twin-H EFI system, but it would be throttle body. If anyone near New Mexico can supply a stepdown engine to this fellow to do some initial programming and fitment - e-mail me or PM me. The final tuning will always be up to the end user, but some initial programming to get in line with the Hudson's characteristics is always necessary. His systems impress me because I went from zero to pretty high up the learning curve thanks to his explanations and they are user friendly and adaptable/flexible. You can start from an easy, general tune and step it up as your own knowledge increases. I like that.
    HET-hudfarm@nctc.com
    Mark Hudson
  • Ok, I picked up...or should I say my wife got it for me...a twin h intake, 2 carter carbs and the air filter canisters. I think she paid 180$ for the set. Was this a good price? I found a linkage at a flea market for 30$ Now I was told that the orig intake system was not as good as the edmunds. And that I should dump the orig and buy an edmunds. What do you think. I'm not going for speed. I'm rebuilding my first hudson and I'm going for looks.
  • Mark how much is that TBI setup going to cost?
    The cost is yet to be nailed down. Still searching components and prices on pieces. A dual one barrel setup with throttle bodies, ECU, and appropriate sensors should be in the $1500.00 neighborhood. This is without the timing controls. The price is not set in concrete however, but similiar setups he already makes are in that range for dual single throats. The MPI setup will be higher, we just don't know how much higher yet.
    Also, I paid $280 for my Edmunds manifold of the same type listed in the e-bay ad. No carbs, no linkage, and definately used.
    I somehow lucked up and also bought a '55 Twin-H manifold off e-bay for $77.00 - which was an absolute steal. A man's gotta have a little luck sometimes!
    Mark
  • $450 is pushing it in my book. But as we know with ebay its what people are willing to pay.
  • So far it's the most I've seen an Edmunds 2X2 of this style go for, and still not at reserve. I'm thiinking this style may fit a short wheelbase better because the centerline of the carbs are closer than a stock Twin H. BTW I received the Clifford 4 barrel Manifold and adapter on Saturday that I ordered the other week. Still Waiting for the headers. Anybody get their headers yet? Mine had to go out for polished finishing.
    That is the most I've ever seen an Edmunds of that type sell for, even at the price it is right now. I gave $280.00 for mine, lucky me?
    Yes, without a doubt that is the twin carbureted option for the short hooded vareity of stepdown. Linkage then becomes the issue. Stock Twin-H linkage would work with the Holley/Weber progressive 2 barrels, but you'll need to fabricate new pull rods.
    Also, I have not recieved my headers - and sent the money in after a conversation with Larry that the headers would be in the next day (March 29th). I requested nothing but headers, no bling whatsoever.
    I do wonder how high that manifold will get?
    Mark
  • Yes in years to come it will be pretty hard to get a good intake option for our Hudsons. When I asked if anyone wanted to get together to allow Clifford to cast a new Twin H intake that would take WA-1's, Webers and TBI I only got 5 takers and that is not enough to get anything done. Larry said it would cost around 7 grand to get the mold made. If we can get 20 people we can get it done. Be nice to have an Aluminum intake.
  • Greetings from Colorado Mark!
    Have you buddy check out the information at http://www.bgsoflex.com/megasquirt.html . I have been following the use of their controller units. Quite an intriguing system. TBI/TPI/Multi Port/Sequential applicable. Single cylinder/multiple cylinder. I have spent many hours reading the various projects that people have attempted/completed using the Megasquirt controller as a starting point. Definately not for folks that can't stick to a project...
    I am currently setting up my '51 Hornet/308 to run with a stock distributor with Pertronics innards, Clifford 4 bbl intake with an Edelbrock 500cfm Performer carb and Clifford dual headers with dual glasspacks. Switching over to 12 negative ground via an Autowire 22 circuit wiring harness. The harness is EFI ready.
    The thought process is to get the Hornet to run well with the above configuration. Then, start to work on the fuel injection system based on the Megasquirt controller. I can tinker and play to my hearts content building the FI system, knowing that full roadability is sitting on the shelf [Carb] ready to be reinstalled and driven...
    My goal for an FI system is driveabilty/reliability at any altitude/temperature condition that will allow me to enjoy towing my teardrop trailer with. There is a LOT more to just putting together some components and calling it done. But, what the heck! We have devoted ourselves to driving/maintaining/restoring cars that haven't been made for almost 50 years! We reinvent the wheel almost daily in our restoration work on our vehicles. We should be able to figure out a reliable FI system.
    OK. I'm off of my soapbox. Gotta go, my wife said that the Hornet floorpans have to come out of the dining room and that she thinks that the box on the kitchen counter that came in today is the new master cylinder...
    George T.
  • George,
    The ECU being considered is the Megasquirt. I'm not as savvy on Megasquirt controllers as my buddy, it is his entire automotive bent. The Megasquirt is probably the most flexible unit that is capable of growing with the user's experiance.
    A.J. has been able to crack into the Megasquirt and we have been bouncing off sensor input assignments to come up with a PROM to run with the flathead. ECUs and knock sensors were not intended to run on noisy flatheads with their flat tappet, mechanical cams. The knock sensors pick up on the valvetrain noise and artificially retard the timing - so we're bypassing it inside the PROM.
    Another consideration was that of total timing control by the ECU rather than it retarding a fixed curve inside the distributor. Again, the Megasquirt is capable of doing that. Its going to take some time to fill in the PROM matrix for both the fuel curves and more than one timing curve - that will be the biggest holdup. That, and the fact I'm in Tennessee and A.J. is in New Mexico. He really needs a running stepdown engine handy to hone in the programming.
    If anyone has a 308/262/232 capable of being used as the "test mule" and can get it to A.J. in New Mexico - e-mail or PM me.
    My build is a 5" stroked 308 bored .075" over, 356 CID. 7x valves with port and relief work flow bench tested with numbers known (this is still in process at this time). I'm wanting to use an Edmunds manifold like the one listed in the auction that started this thread, with MPI injection plumbed into the individual runners. Randy Maas "Hot Street" camshaft (278*@.402 lift) and Clifford dual outlet headers. I'm getting so much tied up in this engine, the EFI only seems logical to unlock the last ounce of what this engine may be able to deliver. The Weber DCNF carbs I was considering are about $800.00 not to mention all the extra goodies it takes to get them honed in! The EFI begins to look economical, from all standpoints considered.
    I'm really interested in your wiring harness research, that is something I haven't even begun to tackle! I'm an engine man, I can't help myself! I build the engine first, then go from there - LOL
    Mark
  • Greetings Mark!
    Take a look at http://www.americanautowire.com/products/Highway_series.cfm . I purchased the Highway 22 harness. I have yet to install it, but everything looks top notch. I called and asked a few questions and their support was knowledgeable and friendly. Additional wire is available in various colors, gauges and markings.
    George T.
  • Mark,
    Could you post the air flow findings once the testing is completed.
    Your combo is just about identicle to mine except mine is .030 over
    and has a homemade dual quad setup with twin 625 Carter AFB's.
    thanks,
    PaceRacer50
  • PaceRacer50
    I certainly will. I have a "test block" which is an otherwise un-serviceable block that is being machined with both the stock valves/reliefs in half (1,2,3) and 7x valves/reliefs in the other (3,4,5). I'll leave at least one in each pair of setups as standard, so folks can get an idea of what to expect with an unmodified chamber or "bolt on" build, and a standard for comparison for me. The rest, will get messed with extensively!
    I'm curious to see how the head choice effects the flow also. Numerous questions I've always had, I hope to get answered.
    Machining is holding me up at present. I'm beginning to get impatient.
    Mark
  • If he wants more than that he should get used to looking at it. He is going to own it a while. I think he thinks because it was never installed it should go for $1500.
