Too much brake pressure
Are you running disc brakes on front? If so are you running a brake pressure balancing valve?
The master cylinder push rod is a simple threaded rod with a lock nut, just back the rod off until you feel minimal clearance to the back of the piston.0
All I have read is that you don't need the 2 psi proportioning valve for the front if the reservoir is higher than the disk calipers. I removed the 2 psi PV when I installed the remote reservoir on the firewall. I kept the 10 psi PV for the rear.
Just installed a Power Brake unit, PBR VH40; but am having a problem bleeding the system so I am certainly not an expert.0 -
I have drum brakes all around on this car. I'm going to try what Bob said.0
It is essential to have that clearance between the rod and the cylinder, otherwise the bleed hole is covered, leading to what you have experienced.0
Ok, so I adjust the rod that goes to the master cylinder and notice afterwards that brake fluid is accumulating in the boot that covers the rod. What is causing that?
You have a leaky piston seal, time for a new master cylinder kit and maybe a hone.0
Jason, I ordered a repair kit from NAPA last week. They found one in Memphis warehouse. Read on site that the number is 138 for my '53. If that isn't right, guess what I am having for lunch?
Came in today but I haven't picked up yet.0 -
Jason, Richard,
Just my opinion, but by the time you get it back together after trying to hone out the pits or having it sleeved, you'll wish you had just replaced it with a new one. The NAPA # for a new cyl. is NMC M3081 and they seem to be fairly common. Our local Po Dunk town has one and I see that there are several at the nearby distribution centers. They fit a ton of Hudsons, a few Hyster forklifts and many mid-fifties Packards.
The rebuilt version (P3081) is shown as being much cheaper but availability is zero according to my info. Shop that number at your favorite AP Store if you don't want NAPA.
Good luck.
F
Correct, Frank. Mine is not leaking but might not be pressurizing enough. $20. vs $100. so I am taking the chance.0
bleed the brakes???
I went to NAPA and according to the salesman, the 138 is for the 48-50 Hudson. The kit is in Columbus, OH and not available until next week. They can have a new MC there in the morning. I elected to purchase a new MC as opposed to rebuilding a part that may be over 67 years old.0
Bingo! We have a winner!
You won't regret going that route, especially if you don't have much/any experience with such repairs.
I think they're off base with the '48-'50 kit application but it doesn't matter. My info says they're all the same '48 thru '54 and even the '55-'57 Hornets (except Jet and Italia, of course).
Good luck.
F
Jason, if you are using the same remote reservoir as I showed you on mine {Wilwood}, you can use a 3/8" bolt shoulder (not threads) to slip in the tubing at the MC QUICKLY then tighten the clamps quickly to save most all of the fluid in the remote resv. WHEN YOU TAKE YOUR MC OFF.
I just did it !!0 -
Richard I took the Wilwood reservoir off because I couldn't get it to stop leaking. The car came with a Toyota forklift fluid reservoir that I relocated from the fender to the firewall and it works great. I'm going to flush out the DOT 3 fluid per Ken U's suggestion, so I'm not going to try to salvage the fluid in the reservoir. Are you going to Sanford Saturday? If I can get bugs worked out on the car that I bought from Lance, I may see you guys there. Even if I can't get the '49 Super Six to cooperate, I'll probably drive the Kaiser as it running pretty decent right now.0
Remember that the wire-type clamp that they furnished with the kit would not stop it from leaking. I had to change to a SS wormgear type of clamp for the hose on the plastic reservoir.
We have too much going on to go to Sanford--I hate it since I didn't make the Christmas party. Give condolences. Thanks.
My car is dead due to the brake problem now anyway. Put on Power Brakes but can't get the system to bleed out !! Took MC off this afternoon to redo it then go again.
Guess I will have to look forward to getting to Lance's now.3/24>> just installed rebuild kit; found out that the 'rubber' check valve (#18) was torn all the way around, no way to check. I am NOT sure that was the problem- doesn't make sense to me, but sometimes nothing does !!!!
- 102 Hudson 1916 - 1929
- 17 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 76 Hudson 8
- 597 Vehicles
