Fluid leak
The car I'm working on has sat for at least three years before I bought it. It has a clutch fluid leak that I initially thought was due to a faulty clutch cover gasket. Upon closer inspection, that doesn't seem to be the source of the leak as the gasket appears to be intact. What are some other sources for this leak?
The copper gaskets under the two plugs.0
One or the other or both the inner and outer seal on the throwout bearing.0
