Hudson - Kaiser - Continental
^^ just brought a 52 Kaiser overrider i plan to use on the rear of my 49 hudson.
looking at putting beehive lights in the tips of the bullets for reverse lights ( had thought exhaust originally)
Should look pretty cool sitting on the Hudson rear bumper and framing the number plate.
So ya im sweet on Kaisers my self.
Kaiser would of had to join up with Hudson by 53 if you ask me. Or at least some type of V8 Should of been out by 53.
Here are my back up lights, 50 watts each, almost hidden. Yes, that is 100 watts!
Also if you look close you will see a back-up camera mounted above the first '3'.
Haiser.....
Kudser.....
Kudson....
Hudser.....
Vooper Vee....0 -
http://wildaboutcarsonline.com/cgi-bin/pub9990262549620.cgi?itemid=9990289766499
"When Packard informed Nash that it was going to "pull the plug" on the supply of their V8, by the end of 1956, AMC was caught without a viable alternative. Acquiring Hudson did not help as their aging 308 in-line six was reasonably powerful but heavy and at the end of its potential. Worse, there really wasn't anyone on the powertrain engineering team with any OHV V8 knowledge, What to do?
Enter David Potter of the recently defunct Kaiser-Frazer Company. Potter was a powertrain engineer for Kaiser and had headed the team that had played with an experimental V8 of their own design; a 288 cu. in. unit primarily created Potter himself. At some point K-F decided it did not have the money to build this engine. At somewhere close to the same point in time, David Potter left Kaiser for a job at AMC, which neatly coincided with George Romey's decision to build a new V-8. When interviewed about the K-F V8 in the 1970s, Potter was vague about whether he brought the design with him or just did something similar from scratch, but surviving pictures of the K-F 288 show an engine that appears identical to the first-generation AMC V8.
The speed of the new AMC V8's development of less than 18 months from decision to production at a time where only testing could bear out paper design suggests that the Kaiser work was accepted as what would normally have been AMC's preproduction process. It also suggests that AMC jumped on David Potter's V8 quite literally as soon as they became aware of its existence. "
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
