52 hornet shocks
Monroe air (pump up) shocks #MA727 at Advance Auto for $70. Call Monroe at 734-384-7809 to see if they fit the 52. I have on my '53.0
If you are into gas shocks... I have a set of four I bought from Kanter 5 years ago. I am happy with them... running 7:10 X 15 bias ply tires on that sedan0
have the spring over on the 53 Sedan rides like on air. Thanks for the info fellows0
Note I found that came from Monro tech for Hudson shocks modern numbers
3008 is 5757 (14" closed and 23.6" Extended) Measured from center of hole to center of hole.
3035 is 5906 (9.4" closed and 14.6" Extended) Measured from the BOTTOM of the stem to the cross-pin.
For further questions or assistance, please contact technical assistance at 734-384-7809 M - F 8:30am - 5:30pm EST.
Monroe Team Member,
Dan
- 96 Essex Super 6
