Removing rocker outer cover panels
Doctorvaux
Hello,
I need to remove the silver outer rocker cover panels on my 1948 2 door super six. Can anyone advise how to go about this please. I suspect the fixings are hidden behind the lower stainless steel trim, but would appreciate any advice before I start to remove them.
Thank you.
Thank you.
Yes, the screws are behind the trims. Go to Ken Cates Hudson Restoration site http://www.hudsonrestoration1948-54.com/ then look up how to remove stainless trim. Its easy to screw it up as Hudson used full length retainers. Wildricks carries new stainless retainers.
Thank you.
