Does '49 Pacemaker have same body as '50 Commodore?
Yes, if it's the same body style.0
Thank you, RL.
Errrr. The Pacemaker body is 5 inches shorter than the Commadore, all in front of the windshield, but they're the same from the cowl back, so you're good with the windows. The front door vent windows for the Commadore will have crank-out vs push out.. A lot of steering parts are different, as well as the hood, fenders etc.0
Thanks, Uncle Josh. Do you think all the door windows would fit any third generation four door Commodore then (1948-1952)?
Wait - '49 Pacemaker???
Wasn't 1950 the first year for the Pacemaker?
The rear side windows of the 52 sedans were longer and the back window was larger0
UJ is correct about the side rear quarter windows. On a sedan rear quarter windows interchange from 48-51. 52-4 will interchange but door glass is the same from 48-54. Rear windows: 48-49 and 1950 coupes. 1950: sedans,broughams: split window one year only. they WILL interchange with the 1951 sedan and brougham if center divider bar is removed. 1952-4 rear windows on sedans and broughams interchange. 52-54 coupe windows interchange. 51 coupe: one year only.0
Wow. A wealth of information. Thanks everyone....And cpr3333, yes it's a '49 Pacemaker and listed that way on the 1960 and 1969 California registrations.
What is the serial number? California DMV made several errors in 1949,
I had a '48 Plymouth they registered as a '49. Parts I ordered didn't fit.
I have a 1950 Pacemaker myself.
Larry
Serial 49170397.
The first 3 digits"491" denotes a 1949 Super 6.
Tipjar, Can you post a picture of your car? That serial number you posted is on the Title as well as the right hand pillar of the car?0
Someone will correct me if I am wrong, but I think the SWB cars have a different firewall.0
Yes, the engine is recessed back under the firewall of the s.w.b. cars.
SuperDave said:Tipjar, Can you post a picture of your car? That serial number you posted is on the Title as well as the right hand pillar of the car?
Lance said:UJ is correct about the side rear quarter windows. On a sedan rear quarter windows interchange from 48-51. 52-4 will interchange but door glass is the same from 48-54. Rear windows: 48-49 and 1950 coupes. 1950: sedans,broughams: split window one year only. they WILL interchange with the 1951 sedan and brougham if center divider bar is removed. 1952-4 rear windows on sedans and broughams interchange. 52-54 coupe windows interchange. 51 coupe: one year only.
Did Hudson make a 49 Pacemaker? I'm with super six on this one. I think your car is a 49 Super 6.0
NO 49 Pacemakers. Serial # matches 1949 Super 6.0
JasonNC said:Did Hudson make a 49 Pacemaker? I'm with super six on this one. I think your car is a 49 Super 6.Ric West IN said:NO 49 Pacemakers. Serial # matches 1949 Super 6.
Show them your Owner Manual, It gives a detailed breakdown of Serial/model numbers .
Or, don't bother, that is probably easiest, Although if you ever have an insurance claim
you may be in for some "fun"0 -
Continuing with the Super 6 identification, following are some pics of two cars identified online as a 1949 Hudson Super 6 with tail lights and a trunk latch different than mine (shown in last two pics). Theirs are cooler!
The gallery pics are taken from here: http://www.motoexotica.com/inventory/listing/1949-hudson-super-6/
And the video still shots are taken from here:https://www.youtube.com/watch?v=KqkgTwaZegY
Also, the gallery car's serial plate shows a 2 for the model number instead of a 1 like mine. And, if this helps, I measured my wheel base and it seems to be 122.5 inches.
Thanks for looking...
you just flicked up pic's of a commodores then a super for the last two pics. The super will have either 1 bulb per tail light or two if it has indicators. (i think as my non indicator hudson has 1 but the tail lights i got on here for the lenses has 2 so guess two is indicator equip models)
the pic you put up of your car above is small but the tail lights looks the same as my 49 super from that angle.
Personally if all the old hudson fanatics on this site who love these old hunks of iron says its a super I would go with it. the amount of obscure knowledge and experience these chaps have is more likely to be correct than some website referencing god knows what put together by sod knows who.
I would rather have a larger Super than the shorter pacemaker but hey each to there own I guess.
Unless you have some sentimental attachment to Pacemakers that is...
Alex
here is a link to my build thread. It is a 1949 Hudson Super. It has a few videos of a walk around that maybe of help to you.
http://openforum.hetclub.org/discussion/169014/49-nailhead-hudson/p1
only pic i could find showing its ass at the moment - im at work and to lazy to upload any from phone.
Thanks, Kustom.
The Motoexotica car is identified in the link as a Super 6, but in most of the text as a Commodore. To really confuse the issue, they use Super 6 Commodore in one spot.
According to my copy of the master parts catalog, here are the serial numbers for 1949:
491 - Super 6
492 - Commodore 6
493 - Super 8
494 - Commodore 8
Serial number 49218113 should be a Commodore 6.
Also, from the same book, the larger, fancier tail light was used on Commodores from 1948 to 1951 and on Hornets in 1951. The smaller triangular tail light was used on Supers from 1948 to 1951 and on Pacemakers from 1950 to 1951. (For some weird reason, for the Commodore/Super it lists the same part number for the right side light from 1948 to 1951 but different part numbers for 1948-1949 and 1950-1951 left side lights.)
Of course, that's just how the cars came out of the factory. Over 70 years, a lot of changes can be made. Ask SuperDave about the 'Superdore' he used to own.
Thanks cpr3333, great information.
- 102 Hudson 1916 - 1929
- 17 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 75 Hudson 8
- 597 Vehicles
