carburetor for a 1936 terraplane
REV
I'm looking for a Hudson terraplane carburetor for my 36 . the car runs but it does'nt idle smooth also the choke wont connect. the carb that's on is a GM rochester
I'm pretty sure that isn't the correct one. It would have been a Carter. For the Terraplane model 61, the carb would have been a 331S. For model 62, a 329S. You could possibly find a used one on Ebay and rebuild it (there are several carb. parts places that sell kits). Or, try some of the Hudson vendors who regularly advertise in the WTN -- they may have an old one kicking around, or possibly even a rebuilt one.
The 36 carb was quite bad in design so many were replaced with a better model - my 36 Terraplane has a universal stromberg - has the added benifit of an adjustable fuel needle etc - probably why yours was scrapped - try to find what modern one fits before installing a 1936 - carbs were quite poor in design till the late 1950's and the technology sort of stopped advancing once fuel injection took over
A Hudson Jet carb works much better on the 212 motor. Carter WA1. There are adjustable jet, universal WA1 models available. I agree with Ken, the original W1 was not much good. The Rochester should work reasonably well, being reasonably simple. I had one of these on a '34 H8 motor and it worked fine. Was off a '47 chev I think.
Thanks for the info it's been helpful0
- 97 Essex Super 6
