47 pickup rear end swap?
Have you considered installing overdrive? That would give you flexibility. I assume you're running the standard 4.11 rearend?
fyi,
I have a '53 Spicer rear in my Trk with spacers but had to bend out the inner fender panels slightly since they are wider than the frame rails. I also have a Ford rear End in one because wheels are the same bolt circle and the U Joint interchanges.
