34/5 Hudson & Terraplane front trays
I'm not sure that front tray is the correct term, I'm referring to the sheet metal with the crankhole.
In the photo the LH item is known to be from a 35T, the RH item came with a 35H8, I'm not sure if its the original or if its complete.
The Terraplane item is about 3 1/2" longer than the one that came with the H8. Is that the way it was, one longer than the other? Or should they both be the same?
Hudson 8 needed the short one to make room for the longer engine0
