formed top rad hose
for our 54 Hornet
From an old post:
You can use these numbers for 1948 - 1954. Upper: Cut to length (All). Gates 21794 or NAPA NBH 8484, Gates 21660 or NAPA NBH 7096 (This is a '48 Chevy lower radiator hose).
For the lower radiator hose with the steel tube, try Gates 24224 or NAPA NBH 632.0 -
Is this same for '53??0
RichardD said:Is this same for '53??
I would assume so? They are pretty much mechanically the same, no?
I haven't tried any of these part numbers myself, I simply searched these forums for an answer for Ray.0 -
I have a number from NAPA that is the exact top rad hose but can not find the part number. Thanks for the help.Richard how do I get into your pictures. Ray
Hey I just found the NAPA number for the top rad hose 7096 NAPA Thanks Hudsonly Ray
Ray, go here & (click ( i) on first photo for info. Have some other albums w/ specific things, ie: removing steering wheel, power brake installation, exhaust, 5" WP pulleys, etc. that I would have share if those are what you want.
Nice pictures, Richard. You've got all the gadgets!0
- 112 Hudson 1916 - 1929
