36 Terriblepain Issue
Is the timing gear in good shape? I knew a fellow who had timing problems off and on. Turned out that the hub of the fiber gear was separating from the outer portion (with the gears). Sometimes the outer section was in sync with the hub, and sometimes it would rotate slightly and then everything was out of whack. I guess the break line was so narrow that it was hard to see the problem unless you looked very carefully.
Good news bad news if it is. I have a NOS on the shelf. Bought 3 of them at an auction for $1 each.0
if it's backfiring through carb the timing is off or valve stuck open.0
I will confess to having had this problem and, after much head-scratching, discovered that I had plug wires crossed.0
Nope, it's wired correctly0
Uncle Josh I would have to go with Allan on this one check your valves and be sure one is not stuck open0
Well, It's not that big a job and it makes no sense to run an 81 yr old fiber gear when I have a NOS on the shelf. Bet it jumped time tho. Will find out and let you all know.0
- 112 Hudson 1916 - 1929
