u-joints
I need three u-joints for a 53 Hudson Hornet.
Do Hudsons use some odd type of u-joints?
Surely Summit has something. The steering u-joint section has near 1.7k items.
I have always used Borgeson but with my current build im trying Unisteer Performance.
Just count the splines and take a measurement of the size or if its DD then just the size and your golden.
I was told that the u-joints for 55-57 Chevys would fit my driveshaft for a 49 Hudson. I purchased three of them from NAPA and had them installed by a company that balanced driveshafts. Apparently this person was correct.
They are about the most common u joints around, used by lots of cars and trucks, Ford, GM, AMC,ETC.0
Yes they are the most common. It's a straight 1310 series u-joint. The Spicer part number is 5-153X, and the NAPA number is 369.0
Tanker, were you aware of Ken Cates' "StepDown" website? It has tons of information for the '48-54 Hudsons, including cross-references on parts. http://hudsonrestoration1948-54.com/0
- 111 Hudson 1916 - 1929
- 570 "How To" - Skills, mechanical and other wise
