borg warnner auto trans
70 views and no one has taken one of these out and put it back in, guess I am on my own. I'll pass along what I learn.
Mike
Mike, you might want to contact Dr Doug WIldrick and see can they provide you some assistance.0
From what I understand, the BW transmissions are a small fraction of the transmissions installed, so it makes sense that not a lot of people might have this info.
Also, does your Wasp have anti-lock brakes??
Well I read the work shop manual on how to remove the BG trans, the first thing was to have a cradle to hold the trans so it can be removed straight back. Pix below, once the trans was free from the torque converter I noticed that on of the ears that drive pump in the trans was missing (not good) Yep the front seal was as hard as a rock. So it looks like I need a torque converter. Any one of any BG trans laying around. iceblade the car had power brakes the master was trashed, I replaced it with a GM unit the found out that the Hudson pedal ratio was wrong so I built a new assy the pedal was some thing I had :-))
Mike
Of course the BW trans I have is missing the torque converter - it may have other parts that are usable.
don't know your location, I am in SLC, UT. Would like to move out the trans.
Gert Kristiansen0
- 96 Essex Super 6
