Question about setting timing.
The white mark will work fine for using your timing light, however in my experience Hudson flat heads seem to respond very well to timing advance. On my 308 I run the highest octane fuel I can get. Run the car about 30 - 40 mph and open the accelerator wide open. Keep advancing the timing until you hear the motor ping,...then retard the timing slightly until the pinging goes away. Go back and check the timing with a light, in my case it is about 6 - 7 degs BTDC
Dave
Since I installed Twin H, the motor is already pinging at high RPM under load. So it seems like I got that step already done! LOL! I've never messed around w/ timing before, so this will be a learning experience for me. My dad should have some idea what he's doing, but I thought it would be helpful to get some experienced advice before we dive in.
When I'm using the light, where should the white line be in relation to the "pointy things?" (sorry, I don't know the terminology... indicators? Arrows?) Should it be right on the edge of the rear one, if that makes sense? In the picture, for instance, it's between the 2nd and 3rd marks, right?0 -
Sounds about right, on a stepdown each line (mark ) is 2 degs of advance. Make sure your vacuum line from the intake to the distributor is connected.
Too much advance will cause two symptoms,..pinging at full throttle as well as the motor will kick back against the starter while cranking
I thought the engine advance was to be checked without the vacuum advance being connected.0
Park is correct, DISconnect the vacuum advance and be sure to plug it. Also, I have found that you need to lay the timing light straight to the hole in the bell housing, other wise "parallax" (the offset angle of the strobe light and your eyes) will cause you to mistime it.
It it is also good to check your mechanical advance in the distributor too. The springs after 60 plus years will stretch and wear out....0 -
I started using a vacuum gage several years ago to time the motor.
http://automotivemileposts.com/garage/v2n8.html
Same, I just don't like the inherent errors in trying to time using the timing marks what with parallelax and aging eyesight.....Have had good success using a vacuum gauge on my '36 Terraplane (212 with 'high' compression of around 7.3:1), looking for the mamimum reading then backing it off 1" or so. No pinking heard at all at sea level using our lowest grade of fuel here in NZ which is 91 equating to a weak batch of US 87.Kdancy said:I started using a vacuum gage several years ago to time the motor.
http://automotivemileposts.com/garage/v2n8.html0 -
Correct on the vacuum line, disconnect for engine timing. however he should check to make sure it was connected before road testing0
- 112 Hudson 1916 - 1929
