Clutch is grabbijng
i called myself fixing my shifting issues by installing new linkage bushings, refilling the clutch fluid, and adjusting the clutch. The car shifts almost perfectly now, but the clutch doesn't engage until ithe pedal is nearly out its its highest point. The clutch plate seems to "grab" the flywheel prematurely, resulting in a rough engagement. I think it has something to do with how I adjusted the clutch, but I'm not sure what I need to try to remedy the problem.
How much freeboard do you have? And check you have put the correct type and quantity of fluid in.0
Jason,
It could be the cross shaft bushings. Wildrick has a kit for redoing those.
http://www.wildrickrestorations.com/hudson-wet-clutch-parts.html
John
