Turn signal switch for 1952 Hudson Hornet
FinnHudson
Does anyone have a working turn signal switch for sale?
My current has 6 wires. I don't need the bezel, only switch with wires.
My one goes round when I turn the signal arm left or right. The arm is ok but some part in the switch is worn and let the arm go round.
Jaakko, I have already sent you an email as you requested.0
Don't understand. What do you mean "let the arm go round"? Which arm?0
Jon he means the turn signal switch lever (arm).0
Does he mean the arm is not engaging the switch, it just loosely flops around? Only reason I'm asking, is to find out if the problem is in the switch, or in the clamp, or even in the absence or misfunction of the canceling pins.
Lance, thank you again. Excellent service as always0
My pleasure Jaakko. Congratulations on your award winning car.0
- 97 Essex Super 6
