Tierod Assembly
I took my 52 Hornet in to have new tires mounted and also asked that they check the alignment. I just received a call that the tie rod adjusting sleeve on the driver side is cracked! I know that Randy Maas sells the tierod ends, and I have a call into him to see if he has the full assembly. I also have a call into Wildrick's. I nevertheless wanted to cast a wider net here to see if anyone has at least the adjustment sleeves.
Did you call Lance Walker?
704) 792-9110
Just left a message with Lance.
Lance was able to source the part.
- 174 The Flathead Forum
- 600 Vehicles
