King Pin Removal/Installation 46 Pickup
Need some advice on removing the spindle pivot pin/king pin. Have all the suspension stripped out of frame and have removed the steering arm & key but cannot get the pins to move. Any suggestions would be most appreciated.
Also, are there oil seals or grease seals between support assembly and spindle assembly as the king pin kit I purchased did not have any?
Any tips on reassembly would be most appreciated also.
Thanks.
Thanks.
Sounds like you need a Hudson Shop Manual -
- 96 Essex Super 6
