232 engine heat control setting
ernie28
edited December 2017 in HUDSON
Just wondering what the correct setting is for the heat control spring. Want to be sure it is not too tight. With a hot motor it is closed at idle but does swing open as you increase the revs. Thought it may have been open at idle on a hot motor.
Also the safety plug has blown out a couple of times and I have just put back with a smear of exhaust sealant.
Thanks in advance for your help.
Alistair
NZHET
