Carb Base Gaskets
21st Century Hudson has them0
I would suggest that you make your own. There some new gasket material that is far superior to the old material for disapating heat. Works much better....0
I got some from large Paul, good price double them up two on bottom two on top0
Hi. I recently purchased a 1931 Hudson grader eight coupe that is missing some parts I would like to replace the wooden spoke wheels with metal ones are there any out there ? I also need back bumpers and the brackets that hold The horn bracket rods. Thanks for any help.0
I'll do a quick follow up for those that might be in need of 262 twin H gaskets. Felpro 8013 were a perfect fit.
