Oil Drain plug size?
iceblade10
Does anyone know the size of the oil drain plug for a '54 308? I don't know if mine is original or not, but it's a square end, not a hex. Does anyone know the size/thread?
It's a NPT. 1/2 I believe. At least the couple of pans I've dealt with are.0
Thank you! That seems like it should be correct. I am thinking about getting a Fumoto valve for the Hornet. I always change my own oil. I put one on my daily driver, and it makes everything a lot easier. You can drain right into a jug without getting your hands dirty. If the Hornet is 1/2 NPT, this is probably the valve I'd need:
http://www.fumotousa.com/parts.php?partnumber=59
