34/5 H8 grille surround and radiator
I'm not sure how the top of the radiator ties in to the top of the grill surround, I'm thinking I'm missing a bracket.
The holes in the grill surround are about level with the back of the top tank, i.e. 4" away from the 2 slotted holes on top of the radiator. Is someone able to explain and/or send a photo of how this goes together? Thanks in advance.
Check with Carl Weber or Jim Digorgio in The roster both have cars to look at.0
After a bit more digging it appears that I have a misleading H8 radiator, 35 H8 radiators don't (normally) have that top tank bracket, only the 35 Terra radiator should have that bracket.0
