Rear wheel hub?
It would help if we knew what year Hudson and part of the country you're in. Most likely you will need a puller. Maybe someone in your area has one to help you out.0
1930 Essex upper michigan0
Upper Michigan covers a large area. What town are you near? Are you in the UP?0
This would be a specialty puller, I believe, for the early cars. Not the universal pullers (rather common) for the mid 1930's and up. I think it might look like this:
The large part is threaded and must match the threads on your hub. Often, a particular puller will match several years and makes of automobile. Watch Ebay, the ones up for auction will say what diameter thread, and the number of threads per inch, that they will fit.
Contact the Essex Advisor of the HET Club0
Thank for the info the town is Gwinn mi0
jmin, try Don Hendrickson, he is in Gladstone, maybe he can help. His # is 906-428-9435. Good luck.
Thanks for the number0
- 102 Hudson 1916 - 1929
- 15 Upcoming Events
- 89 Essex Super 6
- 28.5K HUDSON
- 549 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 73 Hudson 8
- 597 Vehicles
