Not enough distributor advance ?
Trying to get my 308 twin H dialed in so that I can get my vacuum up for my brakes. I’m out of adjustment and when I tried moving my plug wires to help it was worse. Any ideas what to do here?
  • Loosen the base screw just enough to where you can advance the base of the distributor. This is what I had to do with my 39. Advice from Dr Doug and it worked great
  • Thanks! I didn’t even bother to look at the bottom of the distributor
  • No Problem Glad to help
