wheel seals for 1947 pick up.
KenF
edited June 2018 in Parts & Pieces
looking for wheel seals for my 1947 big boy. I have all the bearings and races but seals are elusive.
anybody have any suggestions?
  • Contact Uncle Josh, he is the pickup registrar
  • can you tell me how to contact Uncle Josh?
  • Email
    cramerlp@roadrunner.com
  • Seals, Front Wheel
    TCM
    156252
    36-54  XJet
    Chicago Rawhide
    CR15649
    National
    6407
    NAPA
    16246
    Seals, Rear Wheel Inner
    National
    6356
    36-54  XJet
    Chicago Rawhide
    15960
    Victor
    49136
    National
    482253
    Inner
    National
    5811
    Seals, Rear Wheel Outer
    Victor
    49218
    36-54  XJet
    NAPA
    CR 17310
    RWOuter
    1.75ID
    2.437OD
    .250Thick
    Seals, Rear Wheel Dana
    Inner
    40769S
  • THANK YOU!
    i have already tracked down the front with your help.
    much appreciated!
  • Ken F  Did you get the # of the front wheel seal,and if so what is the #.
     We locals have found a seal that fits the stepdowns front wheels properly. that is it will not touch the bearing but will seal on the shaft and it is a lip type seal.
      The co is reproducing this seal that was in use many years back.
      The part # is SKF 15649 and made in the USA.
      hope this helps.    Rudy B.
  • using Uncle Josh's information here is a
    FRONT SEAL UPDATE:
    S) O.D. - 2.502" M) 63.5 mm
    S) I.D. - 1.562"   M) 40 mm
    S) width - .250"  M) 6.35 mm
    Timken/Federal Mogul/National
    40185 (leather)
    42364s (nitrile)
    SKF/CR
    15649
    these parts are getting hard to find.
    METRIC ALTERNATIVES:
    Hi tech seals OS40627
    Volvo 140246627
    Claas 02122230
    Case IH E7146035
    Simmerring 12003802B
  • Thanks Ken, if i would have looked above i should have seen the info on seals.
    Rudy.
