wheel seals for 1947 pick up.
Contact Uncle Josh, he is the pickup registrar0
can you tell me how to contact Uncle Josh?0
Emailcramerlp@roadrunner.com0
Seals, Front WheelTCM15625236-54 XJetChicago RawhideCR15649National6407NAPA16246Seals, Rear Wheel InnerNational635636-54 XJetChicago Rawhide15960Victor49136National482253InnerNational5811Seals, Rear Wheel OuterVictor4921836-54 XJetNAPACR 17310RWOuter1.75ID2.437OD.250ThickSeals, Rear Wheel DanaInner40769S0
THANK YOU!
i have already tracked down the front with your help.
much appreciated!0 -
Ken F Did you get the # of the front wheel seal,and if so what is the #.
We locals have found a seal that fits the stepdowns front wheels properly. that is it will not touch the bearing but will seal on the shaft and it is a lip type seal.
The co is reproducing this seal that was in use many years back.
The part # is SKF 15649 and made in the USA.
hope this helps. Rudy B.0 -
using Uncle Josh's information here is a
FRONT SEAL UPDATE:
S) O.D. - 2.502" M) 63.5 mm
S) I.D. - 1.562" M) 40 mm
S) width - .250" M) 6.35 mm
Timken/Federal Mogul/National
40185 (leather)
42364s (nitrile)
SKF/CR
15649
these parts are getting hard to find.
METRIC ALTERNATIVES:
Hi tech seals OS40627
Volvo 140246627
Claas 02122230
Case IH E7146035
Simmerring 12003802B
Thanks Ken, if i would have looked above i should have seen the info on seals.
Rudy.0
- 111 Hudson 1916 - 1929
- 570 "How To" - Skills, mechanical and other wise
