Jet wheel cylinders
The user and all related content has been deleted.
  • Syd these are very difficult to come by; sleeving the originals is an option.
  • Because they are alloy pistons they do tend to oxidise very badly, causing them to eventually seize in  the cylinder.  I have found this can be minimized by liberally coating the pistons and end boots with silicone grease, likeplumbers use in  taps.
  • Is making new alloy pistons an option, are they something simple that can be made on a lathe?
  • Probably, but the silicone grease solution works.  You could probably turn up steel pistons.  getting the internal collar that the boot fits over could be tricky though.
  • The user and all related content has been deleted.
  • If you are going to sleeve the cylinders I have found Bronze bushing stock works
    well and is ready available. It machines easy and will polish to a mirror finish.
    It will not rust or tarnish like steel over time.
    Stainless is a better option, but has to be seamless tubing and is very expensive and
    is a lot harder to machine.
  • 36029 is the part number from napa for rear wheel cylinders for the jet. Good luck on finding fronts more than likely will have to be sleeved
