Old splasher points
Anybody have a number and/or source for the screw/spring contact points as used in the old splashers?
  • Not sure if this is what your looking for but it’s what I used in my 37:
  • Ken what is the proper way, or what is the wrong way? I put in a new set of point on my 36 and it had no spark, obviously the wrong way. It seemed the spring was grounding it out.
  • Uncle Josh
    edited August 2018
    Yup, that's the points.  I assume Ken's CS109 was a typo.  Thanks  The screw side is a little tricky to get in there tho.
  • You need a band of insulating material to isolate the spring from the case.  BTW, I had the number in my parts list, just didn't recognize it.  Standard AL5661X.  Just ordered one from Amazon for $9
  • Thanks for the information!
