53 Wasp directional lights. “Blinkers”
I’ve got one blinker on the driver side rear that works and no power to the rest. Any thoughts? The flasher is a cheap Taiwan made 3 prong.
  • Im guessing you are shorting out.
    Also check grounds.
    if that dosnt work get out the multimeter and start testing. or a simple test light. turn on the blinkers and test the wire/terminal leaving the unit. It will be left, ground & right. If it blinks then move further along the wire or skip to the cars light assembly and test there.
    Are the 53 blinker/brake light same bulb or two separate bulbs?
  • Single bulbs. I’ve narrowed it down to the directional switch. I need to find a working one or see what I can do with the original.
