Fuel and water pump for 1948 commodore 6
Your best bet for these parts is:
Dave Kostanek and Tim Cheney
Suppliers of Waterpumps, Carbs, oil pumps, rebuild kits and much more.
7902 Rt.7, Williamsfield Ohio 44903 (440)994-9173 or (440)293-4079 call before 8pm EST0 -
Contact Dave Kostanek in Williamsburg, Ohio. He has both at reasonble price.0
Definitely get one from Dave or Tim. They know Hudson water pumps, which are set up much more precisely than most other makes water pumps. It's easy to set one up with too much impeller clearance, and then sell it as a 'rebuild', when in essence it's really shot!
I've done both of the above, in that I bought a so-called rebuild that turned out to be junk, so then I bought one from Dave like I should have done in the first place. It was done right with a new shaft, bearing, and seal, and the impeller was set perfectly.0 -
Great service too. I highly recommend them aswell.0
