Valve Cover Gaskets Needed
I have an old gasket set for my 37 Hudson 212ci 6cyl engine but the cork valve cover gaskets are broken.  Does anyone make a reusable gasket set or are they still cork?  Is there even material available to cut some?
  • 21st century hudson best price nice people
  • You can also just go to a motor supply shop and buy a few lengths of cork sheets and cut out them by hand - plus you can use the off cuts for small gaskets - the cork and gasket paper is quite cheap - it's quite easy to make your own - not everyone can use a USA company supply ? Cheers ken
  • I've made my own gaskets myself in the past; it's quite a soothing experience :)
  • I have an old gasket set for my 37 Hudson 212ci 6cyl engine but the cork valve cover gaskets are broken.  Does anyone make a reusable gasket set or are they still cork?  Is there even material available to cut some?
    I've got a set it's NORS in good shape I'd be happy to sell. 704 792 911zero
  • Thanks guys, I found some Fel Pro Cork-Rubber 1/8” sheet & made the ones needed!
