Plug wires.
hudsonsplasher1
What is the recommended plug wire size for Commodore 8 engines?
Thanks,
Gene.
Thanks,
Gene.
Dr. Doug Wildrick has them. AndYou can buy suppression 7mm plug wire sets from Speedway listed for Flat Head Fords. They have molded 90 degree plug ends. Cut to fit and put the distributor cap ends on. You have to use them if your using electronic ignition.0
Thanks 29sptphaeton, I appreciate it.29sptphaeton said:Dr. Doug Wildrick has them. AndYou can buy suppression 7mm plug wire sets from Speedway listed for Flat Head Fords. They have molded 90 degree plug ends. Cut to fit and put the distributor cap ends on. You have to use them if your using electronic ignition.
