Question about FAST ignition
The optic wheel located under the rotor button seems to be shifting ever so slightly. It may be the reason I had to get the car towed last week. I think I read where someone glued it in place to make sure that it didn't turn on the distributor shaft and also used blue Loctite to keep the optical base screw from coming loose. Any input on this subject will be appreciated.
Good for you Ken. But to be honest, your response wasn't very helpful.0
You're right about the tech support from FAST. When I called them, the person answering the phone asked me if my car was a 1958 Hudson even though I had clearly told that I was calling about a 1949. When I repeated that I was calling about a '49, he said they didn't sell kits for cars that old....0
