1953 Jet Escutcheons
Need 8 green plastic door/window crank escutcheons in good shape to fit a Jet. Thanks
Too bad someone like Eschelman Molding & Casting can't reproduce the plastic Hudson door escutcheons. I seem to recall from some years back that someone at Eschelman told me that the reason they can't make them is that there are no good ones out there to act as a pattern for a new mold. I'd too like to get a good set for my '53 Super Wasp as well, but looking over the swap meets at the regional and international Hudson meets has only produced warped examples. Good luck with your search!
Dan0 -
3D printing should be an option. Knowing the measurements, overall diameter, diameter of the center hole and the depth of each step could be transfered to a cad program to drive the printer.0
post pics and measurements and if i get time I may give it a go.0
Call Andy Menard in NY. His phone number is in the roster.0
- 111 Hudson 1916 - 1929
- 570 "How To" - Skills, mechanical and other wise
