Photo Needed of Stud
Well if that isnt a loaded title!  But seriously folks, I’m looking for a photo & dimensions of the stud which comes out the back of the intake.  It would be the left bottom area.   Mine broke off & I drilled & tapped it but can’t find my photo of this item.
Heres the hole it goes into on the intake of my 37 coupe.  (6cyl)
  • Yes, it’s a 2 barrel carb off my 37 Hudson coupe.
  • That’s one of the things I’m trying to figure out.  Could be throttle spring or perhaps something with the climate control in the exhaust manifold.  Unfortunately, I didn’t take photos over a year ago when I took it apart, which is why a photo would help.  Lesson learned!
  • Nope, I have the electric hand & this is the connection.  Like I said it’s a stud, I believe to hold a spring or the like.
    If if anyone can share a photograph of this on their car that would help.
  • When I get home today I'll check my 39. It has a 212 with 2 bbl carb
  • Looking at these pictures you will notice there is a manifold that is not tapped, three that are tapped.  Two are OBVIOUSLY A THREADED STUD.  This stud is not a plug, but probably a mounting point for an accessory item used with the original vehicle.  All of the engines are 212s.
  • Val
    Val
    edited October 2018
    This the stud you are asking about. On my 39 is does nothing but sit there. Oldfarmer those are good pics Very nice! .
  • Aha!  The stud is used to attach the bracket which holds the metal “breather tube” from the electric hand up to the air cleaner in place.
    In Ken’s diagram pictures above & you can see one of tubes goes up to the air cleaner.  The bracket & connection to the intake just isn’t representated there.
    Thank you all for helping me figure this out!  Now I can get the proper item tomorrow & install it on the intake.  Then finally install the intake & exhaust manifolds!  Once I have it attached as it should be, I will post the photo as a reference for others if needed in the future.
  • I was test fitting the manifolds with gaskets and decided to shoot that picture which shows what I figured out with everyone’s help.
  • Glad you got it figured out.
    As a farmer I have had numerous times that I needed a special bolt for certain applications. I have attached this S.A.E. fastener specification sheet that I picked up at my local fastener store. I have had to use these more times than I would like to admit. I hope you folks find it as helpful as I have.
    Mike
