Fuel Tank Sending Unit
joe53HH
Dropped the gas tank this weekend on my 53 Hornet. The tank doesn't look bad but the sending unit has holes in the float. Any suggestion as to a part number or place where I can get a replacement?
Thanks, Joe
Thanks, Joe
Sure, the float is the same as Ford. Mac repro Ford parts has new brass floats reasonably priced. I just put one on my '52 and put 2 on the shelf.0
Paul Shuster on this Forum sells new float / Senders0
Allan, Did you replace just the float or the entire sending unit? If you replaced the entire unit does the fuel gauge appear accurate? The sales person at Mac stated the unit is 12 ohms full and 98 ohms empty. Does the positive ground affect the ohms reading?0
While there are several means of repair the reality of how the Hudson Fuel guage and tank sender work are fundamental to the complete repair.0
I only needed to replace the brass float. Exact match.0
Thanks to everyone for the information. Before I proceed I will try to measure the resistance in the old sending unit. If it is good I can then just replace the float. Otherwise I will get a new unit from Paul.0
Resistance should be in the range of 0 to 90 ohms.0
- 175 The Flathead Forum
- 602 Vehicles
