She’s alive!
It’s been 2 years since I took my 37 Hudson coupe apart to fix an intake leak after starting her for the 1st time in 15 years. This lead to the “well since I’m this far I might as well paint the engine, etc, etc, etc.... but this morning she's fired up & back to life once again!
Hopefully I can get the gas tank & lines done shortly then on to the brake system, a new clutch & fixing what’s needed on the electric hand system. I’m hopeful she’ll be done by early spring. I will try to up-load the video I took this morning but I’m not too hopeful it will happen. Either way I will also upload a couple pictures of before & after.
Thanks for everyones help getting me this far, I sincerely appreciate it!!!
Nice!! I wish you continued success! I love the 37 cars as much as the 39's0
If you want to open up your gas tank. clean it and get rid of the troublesome intake screen, I can send ya the procedure. xxxcramerlp@roadrunner.com without the xxx0
Thank you Josh! Fortunately someone built a custom gas tank for it in the past, complete with baffling, etc.
About 2 years ago that was the 1st thing I did as I began to get it running again; cleaned out the tank. Once done, I sprayed a can of WD40 in & rotated it every few days to protect it. Since she’s running again it’s time to put the gas tank back into place & run lines. I’m really getting tired of the funnel to the hose to the fuel pump temporary system!0 -
Amped up. There is no feeling better than a first. Start, Drive, and then Distance. Great job.0
- 96 Essex Super 6
https://youtu.be/0VkrUG3OrPc
