dist cap for my 41
tenbroeck
I have look in my old cross ref parts book and fine no listing for 1941 8cyl even checked /napa can any one give me a p/n and where to get it I even checked Rock Auto. thanks
I have several of the brown bakelite NOS version of this if you need one. 704 792 911 zero0
Depending on what your looking for.... Here is a list of tune up parts I’ve gathered for my 37 Hudson 8cyl which I believe is the same as the 41. I used the NAPA parts a couple years ago, so those I’m confident in using.Dist. Cap: Standard Motor Parts AL92 (??), NAPA AL66.
Points: Standard Motor Parts AL-5661X, NAPA CS709.
Condenser: Standard Motor Parts AL111, NAPA AL868 (can also use AL869 as 2nd choice per napa).
Rotor: Standard Motor Parts AL-102 (AL64??), NAPA AL32.
thank you tenbroeck0
You need a Standard AL493 for your 8 cyl available from Rockauto listed under 1952 Commadore with the 254 engine.0
- 115 Hudson 1916 - 1929
