valve job
I suggest check around your area for a local small Garage that may have a portable machine. (Years ago almost every gas station had a valve grind machine). If your handy, remove the head & manifolds then 'lap' the valves may suffice.0
Google engine rebuilding services near 01570, or in your state. If you can't find something, www.boydsmotorworks.com/ in Gloversville, NY Jack does mine.
Claude,
I have an electric portable valve seat grinder which I used successfully on my l95l 232 Pacemaker engine. I live in Brighton,Mass. Call Per at 617 783 0052 (my phone does not accept texts).
Per0
