Thermostat
What make of vehicle are peofor our 54 Hornet 308 engine. Thanks Hudsonly Ray from Canadaple using for a replacement thermostat
  • Sorry Ken I didn't notice that. You are correct. Thanks for the info. My friend said he cuts a thermostat gasket without cutting the small rectangular hole in the gasket. Would I still have to use frost plug and drill hole in same. Ray from the great white north
  • Can I use a modern thermostat without using the frost plug by using a gasket with NO rectangular hole cut in the gasket. Ray
